Duo Authentication Proxy Logs - a better way to read them
I have a suggestion …
Duo Authentication Proxy Logs - a better way to read them. These logs can prove to be useful in troubleshooting but having them parsed and sorted for clarity and readability would be a big plus. thanks-
jamieis
Hey there @MHG-NavicentHealth,
Do you have any suggestions on how you would improve readability? Could you give a snippet of a current log (with no identifying data) and then show what you suggest us change it to?
We also recently added support for making the logs SIEM-friendly. The options can be found here: https://duo.com/docs/authproxy_reference#main-section
Thanks!
– Jamie
I was thinking that showing the logs from within the admin console would be helpful. Make it a new and standard admin feature where the Authentication Proxy logs can be read from inside the admin web console.
Thanks-
M a r k G e n t r y
This would be awesome, basically like firewall logs - and make them searchable. Would make troubleshooting much easier
