DUO integration with Home Assistant
If it would be possible to get these two products to work together, can someone point me in the right direction of a starting point?
ragen
mkorovesisduo
Level 4
Level 4
Hi Ragen, I’m not particularly familiar with Home Assistant, but it’s possible that you might be able to put something together to protect remote logins to the system using our WebSDK or Auth API.
mkorovesisduo
Level 4
Level 4
