Error ISE and Duo
Fernandomp7
Hey guys,
VPN on Firepower authenticating on ISE -> OK
VPN on Firepower authenticating on Duo -> OK
VPN on Firepower authenticating on ISE calling external Radius (Duo) for MFA -> NOK
Duo's auth proxy logging shows: "20): Cannot decode password using the configured radius_secret. Please ensure the client and Authentication Proxy use the same shared secret."
I have changed secrets several times.. everything else works perfectly.
Duo auth proxy 5.3 and ISE 3.3
Any ideas?
Thanks!
Fernando
Pulkit Mittal
Hi There,
I was thinking if radius secret was being encrypted and then copied. But I found this kb article which has that as one of the causes with others that you may have checked already. But see if it helps.
https://duo.my.site.com/s/article/1168?language=en_US
Pulkit M.
If you find this useful, please mark it helpful and accept the solution.
