Integration with Sailpoint accounts provisioning and certifications
avs1
How does Duo integrate with SailPoint IdentityNow for user provisioning and account certifications?
Is there a document available from Duo?
DuoKristina
Hello again avs,
SailPoint created their Duo integration. We do not have instructions for using it. Reviewing what information they have available, it appears that they created their own UI for Duo MFA instead of integrating our standard Duo web-based prompt, so enrollment and authentication is likely a different experience than what you may be used to in Duo’s own prompt.
You may want to refer to the documentation on the SailPoint site or contact SailPoint directly for more information.
Duo, not DUO.
DuoKristina
Hello again avs,
Duo, not DUO.
