Migrating Access Gateway to Azure AD Conditional Access with Duo MFA
CharlesTennent
We use Duo Access Gateway with on-prim AD for authentication with Microsoft 365.  We want to switch to using Azure AD Conditional Access with Duo MFA.  I followed the instructions for setting up Conditional Access here: https://duo.com/docs/azure-ca
Sets followed
  1. Create the Duo Azure CA Application
  2. Created the Duo MFA Custom Control
  3. I created a policy that filters to a test user and targets all cloud apps, and under Access Controls, I assigned the custom control.
 However, when I go to https://login.microsoftonline.com/ and attempt to sign in it redirects me to the Duo Access Gateway instead of using Microsoft login.
Running what-if confirms it picks up the expected Conditional Access Policy.
Does anyone have a suggestion on how to correct it?
DuoKristina
As long as your Azure custom domain is federated a sign in with a federated user will redirect to the federated IdP.
You could test the conditional access policy with an Azure cloud-only user and then when you are ready to make the switch revert your federated domain back to "managed".
How do I defederate Office 365 from Duo SSO, Duo for AD FS, or Duo Access Gateway?
https://learn.microsoft.com/en-us/powershell/module/msonline/set-msoldomainauthentication?view=azureadps-1.0
If you want to know the detailed effects of converting a federated domain back to managed please contact Microsoft support.
Duo, not DUO.
DuoKristina
Duo, not DUO.
