Salesforce deprecation of API versions less than 30
EClements
Im looking for some documentation around the API version DUO uses with the Salesforce pre-built connector. Salesforce plans to deprecate API versions less than 30.
DuoKristina
If you are referring to Duo SSO for Salesforce then it should be OK as it is not using any Salesforce APIs. It is just a partially preconfigured SAML app.
Duo, not DUO.
