Unable to connecting RHEL 7 duo repository
I am unable to connect the duo RHEL7 repository. Getting Below error
Loaded plugins: product-id, search-disabled-repos, subscription-manager
https://pkg.duosecurity.com/RedHat/7Server/x86_64/repodata/repomd.xml: [Errno 14] curl#7 - “Failed connect to pkg.duosecurity.com:443; Operation now in progress”
Trying other mirror.
DuoKristina
Not sure why you woildn’t be able to connect to the repo. Did you try again since your original post? It’s accessible to me.
Duo, not DUO.
theonetruegim
Did you ever resolve this? I am seeing the same thing.
Can you even curl repodata from cli on that system? Are you also looking for RHEL7 package or a different version?
kristina % curl https://pkg.duosecurity.com/RedHat/7Server/x86_64/repodata/repomd.xml
<?xml version="1.0" encoding="UTF-8"?>
<repomd xmlns="http://linux.duke.edu/metadata/repo" xmlns:rpm="http://linux.duke.edu/metadata/rpm">
 <revision>1704916146</revision>
<data type="filelists">
  <checksum type="sha512">8f99d2541965f2ee31d0d0bdf0ec686c1be2f63124c5ab5ba146ed43f1525361702a4e3fb9ada0e0d556a98026d581fa23cd327e6998c10ce8ad8c004091fb3e</checksum>
  <open-checksum type="sha512">0d944280e9dc42c81fc77d426dcfdcca7d361add05880c5a978b003c131191d26d58ae6b524203bc16dace110aa0efcd8e0b1baa970d5b6788f112a02ff43c8c</open-checksum>
  <location href="repodata/filelists.xml.gz"/>
  <timestamp>1704916146</timestamp>
  <size>2948</size>
  <open-size>29123</open-size>
</data>
<data type="other">
  <checksum type="sha512">f850883988dc27892f1764652ac94070621f87794337bb3ff0c6d69984faf22d2e6d37769d4504b866877d2814103b5ce2ee108daad85547a6aa330ae35bdf28</checksum>
  <open-checksum type="sha512">c820f2915cb45b93a1e360dca0dad6774fe646776e564f0ead33586852361e6d0a7bab5682e9e5ee2b7281ca29fffb7070809261f668887bb1fd026c89eff9e3</open-checksum>
  <location href="repodata/other.xml.gz"/>
  <size>2246</size>
  <open-size>5990</open-size>
</data>
<data type="primary">
  <checksum type="sha512">bb868ef3ea202e6655529a4ff3278f1164d633f98bf013f0214fdd2b2bf7331aa4f8e56b31bf75e019db3c41aad69f6b0867f78c520d1f176f011c93c172a420</checksum>
  <open-checksum type="sha512">acd9aadfaab4a30cb519a4f9a936672dbdff695d1c0937e5a39fdae9bfd13f15c23ecfa6ac58dfe6ed684fd7e671d4e0c50aaabb76c964b2b33fe68c232840ec</open-checksum>
  <location href="repodata/primary.xml.gz"/>
  <size>4102</size>
  <open-size>36295</open-size>
</data>
</repomd>
Duo, not DUO.
