12-15-2015 09:02 AM
Solved! Go to Solution.
12-18-2015 08:32 AM
Connect a layer 3 Cisco Switch to the router. You can create VLANs on the switch, create all the SVIs on the switch, then route out of the switch to the router.
http://www.cisco.com/c/en/us/products/switches/small-business-300-series-managed-switches/index.html
I am not employed by CISCO, but hope this helps.
Have a good Christmas.
12-18-2015 08:32 AM
12-18-2015 06:43 PM
Sounds like exactly what I need! I have found and ordered one as a result of your suggestion. Thank you very much for your help, hope you have a great Christmas as well!
12-21-2015 06:58 AM
No problem. You can also create ACLs on that switch that can will provide an extra layer of security too.
