Bug in RV180 firmware v1.0.1.9?
bakermatthewa
I noticed if you add more than 10 access rules to the Access Rule table, you are unable to reorder past the first 10.
Steps to reproduce:
- Create 11 rules of the same stream direction, outbound or inbound (...I found the bug with outbound, did not test inbound).
- try to reorder one of the first 10 rules to the end of the list, either by entering "11" manually, or by pressing the down arrow.
System responds that "11" is an invalid number, or that the rule cannot be moved.
This issue is not reported in the "Known Issues" section of the release notes for 1.0.1.9.
Does this work for anyone else?
cindy toy
Level 7
Level 7
Hi Matthew,
Please contact the Small Business Support Center to report your bug:
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Te-Kai Liu
Level 7
Level 7
The same issue was listed as a known issue in the RV120W release note.
CSCty01349 Issue—When the Access Rules table contains more than 10 rules, the reorder function
may not work.
Workaround—Delete and re-add the access rules in the desired order.
