Cannot login to 192.168.1.1
dare2tooo
                  I want to configure my RVS4000 router but find that I am unable to login to the 192.168.1.1 site to do so. The "admin" username and password is not working. Maybe I do not have to as my internet connection seems to be working fine. Thanks for any help.
33 Replies 33
leoliang2021
192.168.1.1 is the default login path of many routers, some of which are 192.168.0.1. The login paths of different models are different. For example, the login paths of tp link archer ax90 and ASUS router are different
My name is Nikola and I'm a Cisco Small Business Devices Team member.
Can you tried with a different IP address assigned through DHCP server or Network and Sharing Center. Check if the address is pingable.
Thank you in advance,
techbusk
If you are not able to log in your router then you can simply try  10.0.0.0.1
jennlyc dawn
techbusk
192.168.0.1 is the default gateway that is used by routers and modems such as D-Link as default IP address for logging the admin panel.
jennlyc dawn
