Cisco Configuration Assistant??
Charlie Mayes
                                 Hello Guys,
                                                  I am trying to download a the CCA software but need to know what type of account I need to download it?
                                                 Partner, Guest or Other?
2 Accepted Solutions
Steven DiStefano
We have a vanuty URL:   www.cisco.com/go/configassist
The latest is 2.2(4).
You should be able to get it as a registered Partner, I believe...
Steve
Small Business Sales
Steve
Hi Steve,
As per the link it says  You must be a registered Cisco.com user, but you need no other access privileges,check out the below link for step by step procedure to download CCA.
http://www.cisco.mn/en/US/docs/net_mgmt/cisco_configuration_assistant/version2_2_2/administration_guide/cca_222_sbcs_admin_guide.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
5 Replies 5
Ganesh Hariharan
    Hello Guys,
You may download the Assistant at no charge,check out the below link for the same
http://tools.cisco.com/support/downloads/pub/InterfaceModuleSWT.x?mdfid=281010085&mdfLevel=null&treeName=Network+Management&modelName=Cisco+Configuration+Assistant+(CCA)&treeMdfId=268439477&imst=N
Hope to help !!
Ganesh.H
If helpful do rate the post
Steven DiStefano
Steve
Steve
Hi Steve,
Hope to Help !!
Ganesh.H
Hello Ganesh.H,
                                                That was just what I needed.
        Thanks.
                          Hello Steve,
        Thanks.
