Has anyone enountered (and hopefully resolved!) this problem on Win 7?
(Aplogies if I'm asking in the wrong discussion group - I'm new to Cisco Support Forums)
The application installs ok and all the checks pass correctly. But when we launch the application it displays a dialog with following text:
"Internal error has occurred. Close Cisco Configuration Professional and restart the application"
Restarting the application only results in the same error.
Windows Application log reports the attached errors alternately with each attempt to start it.
The closest description I can find to this problem in the Release Notes is in the Caveats for V2.2 (CSCtg57954). However, the workaround suggested there does not resolve it.
Relevant version information:
Windows 7 32-bit Service Pack 1
Java versions tried: V6, Update 33; V7 Update 5.
CISCO Configuration Professional Version 2.6. Build Number 1112081100.
