Cisco ISR 1000 Series for FTTP Line 1000/50
ST-IOS
Hi all,
Context: Just signed up to a new NBN service with Launtel 1000/50 looking for a Cisco ISR with relatively low noise to use as a home router. I want a ISR that can run at or close to the line speed.
Just had a question in regards to the ISR 1100 series, does any router support 1Gb through-put? I have been looking at a Cisco ISR 1100 (C1121X-8PLTEP ).
Platform performance
Ref: Cisco 1000 Series Integrated Services Routers Data Sheet - Cisco
Table 17.     Cisco 112x ISR Controller Mode (SD-WAN) performance specifications – 17.9 Release (Bidirectional)
Feature
C112x(X)-8P
C112x-4P
SD-WAN IPsec throughput
(1400 bytes)
1889 Mbps
1426 Mbps
SD-WAN IPsec throughput (IMIX)
465 Mbps
338 Mbps
SD-WAN overlay tunnels
200
200
@ST-IOS
 It will vary according to the model
Key features
●      Industry-leading hardware coupled with feature-rich software combine to make high-performance small-office routers. Up to 800 Mbps IMIX encrypted throughput.
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
@ST-IOS
Key features
Leo Laohoo
According to the Data Sheet (Table 18), an 1121 can support up to 1673 Mbps (non-SDWAN).
For NBN use, this is fine.  Do take extra steps to lock down the router, particularly put ACLs in place to keep unwanted IP addresses from discovering the router.
