Cisco RV082 10/100 8PC
savio.martins
I am Unable to Open a Particular website, the Website Address is http://www.royalcollege.ca/portal/page/portal/rc/public, but when i bypass the router it works from modem, any answer as to why or what settings are wrong on the VPN Router. i am connected wirelessly on my windows 7 computer, and 2 mac computers and it does not work on either of them.
Any answers ?
7 Replies 7
Michael Vandergrift
Savio,
What DNS settings is your PC using?  Are you able to browse to http://67.22.96.236?  You may need to set your DNS to something like 8.8.8.8 or 4.2.2.2.  Also, check and make sure you don't have any Access List restrictions that would prevent access to that site.
My Current configuration settings are attached, please let me know if any changes needs to be done.
Savio Martins
Try changing DNS Server 1: to 8.8.8.8.  Or you can set the DNS manually on your PC to 8.8.8.8.
what about the DNS 2 address should i leave it the same.
You shouldn't need to change it.
Thankyou for your help Michael, it worked.
Savio Martins
Did you try browsing to http://67.22.96.236?
