I was wondering if the RV120W VPN supported iOS. More specifically, I am using this router ONLY for VPN (not for wifi) and I am attempting to use it with iOS devices primarily. I have set up the VPN router with the correct Remote / Local information, but when trying to connect with my iOS device I receive the following error in the Cisco logs:
2000-01-07 00:32:09: [rv120w][IKE] ERROR: Local configuration for xx.xx.xx.xx[4500] does not have mode config
Is this a limitation of the router, or is there a specific setting I need in the IKE policy?
Thanks in advanced,
Sean
