Cisco RV180 problem with DHCP and Vlan
Razvan Popescu
I have a RV180 router and I need it mainly for routing a /26 subnet over three vlans
VLAN ID
IP Address
Subnet Mask
DHCP Mode
DNS Proxy Status
82.xx.xx.xx
255.255.255.192
DHCP Server
Enabled
255.255.255.0
DHCP Server
Enabled
255.255.255.0
DHCP Server
Enabled
vlan 1 (default)
will be the default one and will have the ip 82.x.x.x, on this vlan I want to put two webservers with static/external ip
vlan2
will be for office use with the ip 192.168.10.1. I need for this DHCP enabled to give computers the correct ip in form 192.168.10.x. I will be configuring the static DHCP later on for those comps.
vlan3
will be for management with the ip 192.168.3.1. I don’t need DHCP will be using a static ip.
VLAN ID
Description
Inter VLAN Routing
Device Management
Port 1
Port 2
Port 3
Port 4
Default
Enabled
Enabled
Untagged
Untagged
Excluded
Excluded
Vlan2
Enabled
Enabled
Excluded
Excluded
Excluded
Untagged
Vlan3
Enabled
Enabled
Excluded
Excluded
Untagged
Excluded
Everything works, on port 1 the servers work with their static ip, on port 4 the office computers receive the correct ip from DHCP, 192.168.10.x and even on port 3 the dhcp works for my management ip. But randomly some computers start losing connectivity, some regain it but some won’t connect even if I use a static ip corresponding to their vlan. When I say they won’t connect I mean I can’t ping their gateway or the management ip of the router (all vlans have inter vlan routing enabled so no matter on what vlan I am, I can access the web interface for the router). It;s not from security settings on the computers or firewall.
I discovered they will connect if I use the static ip corresponding to vlan1 82.xx.xx.xx, but not the ip corresponding to their port number. DHCP stops working for a while, it will recover randomly.
What am I doing wrong? I don’t have other switches I could use for DHCP, I thought I could use some managed switches to solve the DHCP problem.
Razvan
Razvan Popescu
I tried with only two vlans and set the DHCP active only for the office "vlan2". Computers receive the correct ip but some of them won't register on the network, i tried to set the ip manualy on the computers but that computer will still be isolated.
Ex: computer A receives ip 192.168.10.25, Subnet 255.255.255.0, Gateway 192.168.10.1, for 2-3 minutes i can access the router on 192.168.10.1 and the internet, after a random time interval the gateway won't even respond to ping.It's not from firewall related issues as i set to accept all both incoming and outgoing. If i set a manual ip corresponding to vlan1 "default" everything works.It's like that computer is isolated so i believe it has to do with the asignment of Tagged, untagged and Excluded settings on the vlans.
