ISA550 and multiple subnets?
rodman.frowert
Just picked up a ISA550 and have been playing around with it a bit but seem to be having some trouble.  I have two LAN subnets in my small business with approx 10 hosts per subnet.  I'd like to use the ISA550 to route between them (and to the internet) but can't seem to figure out how.  Is it just as simple as creating two VLANS?  Can the ISA550 route VLAN traffic?
With my old RV042G, I had the option to setup multiple subnets inside the setup menu but I don't see any such area with the 550.  Any help would be appreciated!
Te-Kai Liu
Level 7
Level 7
Yes, and Yes. Once a VLAN is created, you could configure its IP subnet. ISA550 supports inter-VLAN routing.
Te-Kai Liu
Level 7
Level 7
Great! I got it setup and working with that info!
Hi Rodman!
I have the same Issue. How did you solve the problem ?
Each port is configurable.  So you just need to create a VLAN name and IP/Subnet for each port.
For example, if you only have two subnets then you would do this:
Port 1 IP address/network mask - 192.168.1.0/24
VLAN  name for Port 1 - office_network
Port 2 IP address/network mask - 192.168.2.0/24
VLAN name for Port 2 - server_network
