02-26-2015 09:44 AM
I try to connect my laptop to RV320 by VPN SSL connection.
Every 8-15 minuets i get session expired, even when I am working. I tried to increase "Login Time" field to 9999 but without success
The problem also occurs on other computers.
Any ideas?
Thanks.
02-27-2015 03:58 PM
Hello
with "Login Time" field you mean
or
03-01-2015 03:42 AM
I mean to:
03-01-2015 04:28 AM
Thus you are modifying correct value. According related Cisco KB article the "Session Idle Time" value means "enter the time, in minutes, before the existing session terminates after the connection becomes idle".
Isn't your public IP address changed during your work? Changed client IP address (from VPN Router point of view) is considered as good reason for breaking VPN connection.
Have you tried to use different browser and try to reproduce with same results?
