Cisco RV325 VPN Issues
wchestnut
I'm trying to configure ANY VPN to work with an iPad but I can't get anything to work.  I found on video on setting up SSL VPN which should be clientless.  However, there is no Firewall -> SSL VPN option to check, nor is there an SSL VPN menu option on the left.  I believe the latest firmware is installed: 1.4.2.22
PaulWilkins6710
If you 'downgrade' the firmware to v1.3 then the SSL VPN re-appears. I had to do the same on my RV320, as like you, I'm having a 'mare' with setting up any VPN.
After 3 different sessions with Support, turns out a reboot of the Router fixed the Easy VPN issue so now IPSec is working.  It's a strange little device.  I don't think we'll be recommending them to our customers in the future.
Wade
Interesting.. so you had to configure the Easy VPN and the reboot the router to bring those settings into effect?
Hmm perhaps worth giving it a go.
Thanks for your suggesting, I'm willing to try anything!
Yeah, turns it it actually was "easy", but just didn't work until the reboot.
Good luck!
Wade
