CISCO RV345 WITH UNIFI
uniquimica
I plan to buy the RV345 for , but my equipment is all UNIFI.
Does anyone use it too?
Just install and use or do you have any recommendations?
Martin Aleksandrov
Why you are going to implement the RV router within the UNIFI environment? Depending on what you are trying to achieve there should be no major obstacles/stoppers. However, as a best practice, we would recommend using one Vendor device deployment.
Martin Aleksandrov
