Cisco SDM wizard error, can anyone help?
farenas77
Hi, i have a cisco 871 w router and sdm version 2.5 (upgraded, originally with v 2.2), when i run the "first time setup wizard" i enter the data into fields, but when i click next to change to the WAN configuration screen nothing happen and  can't finish the wizard, when i try to configure it by normal SDM (FE4) i got errors and again i can't make it work.
The originally version of sdm 2.2 didn't work
Upgraded to version 2.5, didn''t work
i used the reset button, didn't work
0 Replies 0
