Cisco WAP 121 PoE does not work
astrotomas
Hello!
I have a question about the WAP 121 access point that supports PoE. The device works fine with a regular power adapter but it does not turn on if I connect it with a router and using a PoE injector in between.
Any idea what the issue might be? I am using an ethernet cat5e cable to connect the PoE injector with the Cisco access point.
I´d recommend you try to piower something else with this power injector. The way I see it, chances are it is the problem.
astrotomas
Thanks for the suggestion! Unfortunately I don't have another device to test the PoE but at least the lights of the PoE injector are working so that seems fine.
astrotomas
I am using this PoE injector:
https://www.wifishop.nl/ubiquiti-poe-injector-48v-24w-gigabit/pid=34590
In combination with this access point:
https://www.cisco.com/c/en/us/products/wireless/wap121-wireless-n-access-point-single-point-setup/index.html
But the access point does not turn on when using the PoE injector.
Any suggestions what could be the problem?
