Cisco WAP321 Q1 IC About
The cisco wap321 access point I used in the automation system is no longer working. I could not reset. It did not return to factory settings. I opened it up and the Q1 IC is burnt out. How can I change it. What is its value? Is there a datasheet?
akashar2
Please find the link for datasheet as well as link for support contact of Cisco-TAC .
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
https://www.secureitstore.com/datasheets/sbwireless-300-data-sheet.pdf.
The support depends on service level your devices is entitled for . You can contact TAC support center as per your location and time zone .
