DNS problems
grant
Every so often, one of the computers on our system will complain with a "dns probe finished bad config" error message.  All of the computers are getting the DNS servers from our router.
I'm able to "fix" the problem by updating the first DNS server on the router (alternate between 8.8.8.8 and 8.8.4.4) and that makes everything work for a while.  Sooner or later though, one of the computers will have trouble accessing things and will give the DNS error.  Any thoughts?  Thank you for the help!
Michal Bruncko
Level 4
Level 4
  • Don't fill DNS servers field in DHCP configuration of your router (this keeps to be your router's IP as DNS server IP)
  • Try to use DNS servers of your ISP provider instead
