Download and Install RV180W Firmware Upgrade
marnold02
I received a warning when I accessed the router site which indicated;
"Your connection is not private
Attackers might be trying to steal your information from 192.168.50.1 (for example, passwords, messages, or credit cards)."
I have downloaded the firmware upgrade.  However, when I execute the file, it executes a command to burn file to my DVD drive.
When allow the command to proceed, window returns the following;
"The selected disc image file isn't valid."
Any suggestions on how to proceed with upgrading the firmware.
aateek singh
Please follow the procedure mentioned below to proceed with upgrading the firmware
Upgrading Firmware
Cisco RV180/RV180W Administration Guide
Upgrading Firmware
CAUTION During a firmware upgrade, do not try to go online, turn off the device, shut down
the PC, or interrupt the process in any way until the operation is complete. This
process takes about a minute, including the reboot process. Interrupting the
upgrade process at specific points when the flash is being written to may corrupt
the flash memory and render the router unusable.
You can upgrade to a newer firmware version from the Administration > Firmware
Upgrade page. To upgrade:
STEP 1 Click Browse, locate and select the downloaded firmware, and click Upload.
STEP 2 (Optional) Check the box to reset all configuration and settings to the default
values. Do not check this box if you want to keep any settings you have changed
on the router!
STEP 3 Click Start Firmware Upgrade. After the new firmware image is validated, the new
image is written to flash, and the router is automatically rebooted with the new
firmware. Choose Status > System Summary to make sure the router installed the
new firmware version.
And then to reboot it
To reboot the router, choose Administration > Reboot Router. Click Reboot.
Aateek Singh
Network Engineer
Spooster IT Services
Please refer to the following link
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv180w/administration/guide/rv180w_admin.pdf
Aateek Singh
Network Engineer
