09-26-2011 11:41 AM
Hey folks
I just bought an RV220w. My first act was updating th firmware to 1.0.2.4.
Unfortunately I was not able to configure the router for vlan purpose 'cause the "Port VLAN" point was missing in the webinterface.
I performed several factory reset but it didnt work for me - so I got back to firmware 1.0.1.0.
Any solutions for that? Is this a known issue?
regards from Switzerland
Chris
09-30-2011 01:40 AM
Firstly download a new image. reset to factory defaults, then try uploading the image again, possibly using a different browser.
10-02-2011 04:04 AM
Hi Simon. Thanks for your advice. I tried again with Firefox6 and IE9. I could download the image and load the firmware without any problems. Unfortunately the port vlan menu settings are still missing. Any other suggestions?
10-03-2011 10:40 AM
So you have managed to load the newer firmware yes?
10-03-2011 01:51 PM
Yes of course... like i did it the last time.
But since the upload i am not able to set the port mode... and it looks like it is in access mode
01-25-2012 12:43 PM
hi folks
As a result of my problem with the rv220w last fall, I decided tu use my bintec rs120.
There was still a little hope when I saw the "new" firmware 1.0.3.5 last weekend
Although I uploaded the firmware successfully I still cannot set the ports to trunk mode (see the pic above).
So there is still my original question:
01-25-2012 01:04 PM
Chris,
The VLAN function of firmware 1.0.3.5 may require a reset to factory default if your configuration originated from earlier firmware. If you were using Trunk mode for a given port on RV220W, you could use the tagged option with firmware 1.0.3.5.
The following thread has some discussion you might be interested in.
01-25-2012 03:52 PM
Thanks for fast reply. The thread you mentioned seems to be familiar
As you can see I had this problem already with firmware version 1.0.2.4.
There is currently no configuration on the router... I did a factory reset before and after the upgrade.
My problem is that by default all ports are in access mode.
As soon as I assign multiple (tagged) vlan to one port the router doesn't respond.
A workaround could be to configure every vlan on a single port but this cannot be a final solution.
01-25-2012 03:59 PM
This does not sound right. You might want to call the small business support center to get your issue checked out.
01-25-2012 04:09 PM
hm yeah thats probably the best solution...
