gateway to gateway configure
rufneck55
Hi,all
i have few questions that ive been trouble for days and months trying to figured it out but fail cause my limited knowledge of networking.
As see in the picture, Im trying to to use VPN to connect my workside with home network. i cant seem the configure it right. what ip address or subnet should i use for this or that. there also two of Ubiquiti loco M5s that connect both site over km away. i dont know what should assign it to be bridge or router? and wan2 or both rv042s, pptp or ppoe or brisde or even static.
if anyone can help teach me how step by step to configure it right. Thank you1.jpg
 I´ll try to help you:
Well, this is not relevant. You can use any stating they are different. For example, you can use 192.168.1.X for home and 192.168.2.x for Work. Or even 172.16.1.X for home and 10.10.10.X for Work. It is up to you.
192.168.x.x
172.16.x.x
10.x.x.x
Those are free to use.
 This is more difficult. I know nothing about Ubiquiti. You need to find help on some Ubiquiti forum.
Watch this video. You can even use IP addressing as example.
https://www.youtube.com/watch?v=DuYqvpTrf3E
192.168.x.x
172.16.x.x
10.x.x.x
Thanks for rating and changing the status to solved. This helps make this forum better.
-If I helped you somehow, please, rate it as useful.-
