Hello everyone,
i have a ISR C892FSP-K9.
we have IKEv2 VPN, IPS, and 23 Static routes which are running on the Router.
when i download a file (for example ubuntu Desktop for the ubunto.com) the CPU goes 99%.
is it possible to control that traffic and use less than 50-60% of the bandwindth?
why? because i want to use most of the bandwidth through the VPN connection.
1 per 2-3 weeks, they loose internet / connection the users and i am now a days investigating if the problem is on the Cisco device or on the Provider Router. I want to make it clear and see if that high CPU influence the operation of the Router and if yes i want to relax the performance of the device.
thank you so much in advanced.
Thomas
