Hot to use DoT / DoH encryption on DNS requests
hp bo
Hi, I am trying to connect a RV260P router to the WAN using for the DHCP requests a resolver using DoT or DoH encryption for the DNS requests. Entering the static DNS to the appropriate resolver the internet connection for new requests does not work any more. Seems I am missing a setting anywhere else in the router.
The Setting "Use DHCP Provided DNS Server" works but routes through unsecured DNS resolver.
Is there anyone in here that might help me on?
Thank's a lot!
nagrajk1969
Ok, just for reference
- the "DoH" is DNS-resolutions/queries/responses-over-HTTPS, and this https "secure" session is between the dns-clientbet-querier  and the dns-server (that supports DoH). And the point to note is this https session is using the standard TCP/443 port
- the "DoT" is dns-session (for dns-resolution-query-response-etc) that is "DNS over TLS" which uses TCP/853. This secure TLS DoT session is established between the dns-client-querier and the dns-server (that supports DoT)
Now your deployment is as below:
PC1(192.168.1.2)------192.168.1.1vlan1[RV260]wan-----[isp-router]----------[DNS-server: DoH/DoT]----{internet}
And in this above deployment there are 2 parts:
1. The RV260 connects to ISP and gets its wan-ipaddress assigned thru DHCP (in which case the public-dns-server ipaddr is also assigned to RV260 thru this dhcp-connection on the wan-interface - OR maybe the wan-interface is configured with a public static-ip-address assigned by the ISP and alongwith it the dns-server-ipaddr is also configured - generally in the "/etc/resolv.conf" file on the router
a) now lets assume that this public-isp dns-server/dns-resolver ipaddress (say for example ) is 202.202.202.5 and lets assume that it support DoH (using https on tcp/443) and DoT (using TLS on TCP/853) and also if the dns-client sends a dns-query/request that is unencrypted/plain, it will also resolve the dns-query
b) Now on the this RV260, there "maybe" be some "applications" that would "initiate" connections (tcp/udp) from the RV260 itself to some remote-servers and these connection requests "could" be to a FQDN (such as some update-server with fqdn say for example "updateserver.cisco.com") and this FQDN needs to be resolved to a actual IP-address, and So now what would happen is that:
- either the "application" running on the RV260 would be intelligent enough to have support for sending by itself a dns-query to resolve this FQDN, and therefore simply get the dns-server ipaddress from the resolv.conf file AND send the dns-query/request to the dns-server
- or maybe the application may depend on a underlying dns-client-resolver service that would use the dns-server ipaddress configured in the resolv.conf file and send the dns-query and update the local application with the response from the dns-server
c) And sometimes there will be certain services that are run on the RV260 such as "DNS-Proxy" for the dns-queries recieved from lan-dhcp-clients that are forwarded onto the actual public-dns-server-ipaddress configured in the /etc/resolv.conf file on RV260
d) Or when we say run a ping on RV260 to a destination using a FQDN...and this fqdn is resolved by the underlying dns-client-service on the RV260
So the present state on RV260 is that none of the dns-queries/requests sent "from the RV260" (arising out of above scenarios in points1a-1d) are encrypted and the dns-request initiated/originating "from RV260 itself" PRESENTLY DO NOT HAVE SUPPORT FOR DNS-over-HTTPs(DoH) or DNS-over-TLS(DoT)
2. The second part after RV260 connects to ISP and configures the wan-ipaddr AND the public/isp dns-server-ipaddress (got either from ISP or configured by the user) are configured in the resolv.conf file, is the process of the lan-hosts connected to this RV260 and the lan-hosts are assigned their "ipaddress/def-gw and dns-server-ipddressses" from the dhcp-server running on RV260 vlanX-lan-interface
a) So in the dhcp-server on RV260 there are 3 options for assigning the dns-server-ipaddresses to the lan-client-pcs:
- use dns-proxy (this will result in the lan-clients configured with the dns-ipaddr the same as the default-gw ipaddress which is the RV260-vlanX-lan-interface-ipaddress. This is the default setting
- usp dns-from-isp (this will be the same dns-server ipaddresses configured in the /etc/resolv.conf file on RV260)
- use-these-dns-servers (and configure them manually/explicitly by the user). In this case the user will configure explicitly the public-dns-server ipaddresses and these will be assigned to the lan-pc thru the dhcp
b) So in this case if you refer to the brief description of "DoH/DoT" functionality, its the "applications(such as Firefox/Chrome/Edge browsers), and maybe if supported the underlying os-specific dns-client-resolver service/application on the lan-pc that would be "initiating" the dns-queries/requests to the configured dns-server ipaddress
- And these dns-queries/requests originating/initiated from the lan-pc would be IF SUPPORTED using DoH and/or DoT features for secure connections between the lan-pc and the dns-server
c) And if the dns-server is on the internet (or in ISP-network) and supports DoH/DoT, then the corresponding dns-queries from the LAN-PCs behind the RV260 would be basically https(tcp/443) and tls (tcp/853) connections that will be NATed/Masqueraded and routed/forwarded across the RV260 simply as https/TLS connections.
d) So generally for all DoH/DoT dns-queries  flowing between the Lan-PCs and the remote-wan-public DNS-servers, the RV260 is not all involved except for forwarding/routing these traffic as https/tls connections as any other similar connections between the lan-pc and the internet hosts
e) The above point is true for most times, EXCEPT WHEN THE "USE DNS-PROXY" SETTING IS SELECTED IN THE DHCP-SERVER CONFIG ON RV260 FOR LAN-HOSTS
- This is the default-setting, and in this case what's happening is that although the lan-pc (applications running on the PC) are having support for initiating dns-queries using DoH/DoT, the dns-server to which the lan-hosts are sending the DoH-DoT requests is the RV260 lan-interface ipaddress (say in this example 192.168.1.1)....and these dns-requests are proxied by RV260 and further sent to the dns-server as plain-unencrypted(normal dns queries using udp/53 and/or tcp/53).  So in this case since the dns-client on RV260 does not itself have support for DoH/DoT, the dns-request within DoH/DoT sessions from the lan-pc will fail and not get established
So in summary you should not configure "use dns-proxy" and maybe try with the other 2 settings for LAN-PCs to start using DoH/DoT sessions to the internet-DNS-server...across the RV260
- And as for any dns-queries from RV260, there is NO support as of now for DoH/DoT and therefore you will see plain dns-sessions originating out of RV260
nagrajk1969
- From where is is this "internet-connection for new requests" coming from?...is it from the lan-hosts (connected to the vlan1/lan interface of RV260)?
- If your internal-lan hosts are unable to use the specific dns-resolver, and if they are all getting their ipaddress from the dhcp-server running on RV260,,,then maybe you should set the "use dns proxy" settings in the dhcp-server config on rv260
hp bo
Hi, thanks for your thoughts and help
yes, the new requests are coming from the host on vlan1
yes, the internal host receive their IP from the DHCP server running on RV260
the DNS-server setting is / was already set to "use DNS proxy"
why does it not work?
Configuring Firefox to use the IP of the DNS-DoT resolver instead of using the resolver IP's provided by the DHCP, Firefox can handle the thing.
I also added in the service management section the port 853 mentioned for the DNS-server - without success - even thought Firefox was prior to this already capable
The idea would be to just provide for any computer in the network DoT-encrypted DNS requests, regardless of the setting of the browser
Further help would be very much appreciated
Apropos: it would not matter if it would be DoH instead of DoT - at least one working
Kind regards
nagrajk1969
hp bo
Hi nagrajk1969,
Thank you very much for all these explanations. They help me understand the topic and problem.
Seems as if I can solve my desire in the setting "use DNS as below".
Regardless I hope that Cisco will work on the implementation of DoH / DoT into one of the next near future firmware versions for the RV260. To my understanding that would go inline with the umbrella-idea.
Thank you again!
Kind regards
