Hi Everyone,
Even though I have experience with configuring routers, I got stuck configuring SSL VPN for a Cisco RV220W router.
I read the documentation completely and realised there is a server part and a client part, but the Cisco doc is not clear, there is no examples on how to do this.
I would appreciate if someone could provide a practical example on how to do this.
I believe with SSL VPN I can have a clientless connection to the SSL VPN server just using a browser.
Do I need to get an certified SSL certificate or can I generate my own self-signed certificate.
When setting up SSL VPN is the client section of the configuration used to configure remote client computers or is it used to configure the router as a client to a to another SSL VPN server.
I would truly appreciate if someone could give me a practical example.
Thanks in advance.
Kind regards
Alfred
