How to establish VPN with Cisco SPA525G2 and Router RV320
aboukouris
I have managed to establish PPTP and SSL VPN gateways with my RV320.
I try to connect an SPA525G2 phone with the RV320 but can't do it.
What options should be selected in the RV320 and what do I have to do to the phone (that's very simple as I see).
Thank you,
Alex
aboukouris
Is really anyone in this cisco forums from CISCO ????
Hi Aboukouris,
SPA525G/SPA525G2 is based on Cisco AnyConnect, so in this case we need to have a router which support Anyconnect such ISA500 or UC500 ...
please found the PDF file attached to this post there is a question and answers for more (page 4)
"Q. What types of SSL VPNs are supported on the phone?
A. Cisco AnyConnect SSL VPN is supported."
Mehdi
So, if I understood right, your CISCO VPN ROUTER RV380 and all the Cisco Small Business Routers are NOT COMPATIBLE with VPN with SPA525G phones?
Really? Cisco's products are not compatible?
Not all the Cisco Small Business Router are not compatible with VPN with SPA525G phones, there is UC500 series (Routers,Firewall with voice module Call Control) and ISA500 series (Integrated Security Appliances). they support Anyconnect Secure mobility Client
Mehdi
