How to save XML configuration on WRP400
quesse
How can I save the XML configuration file (both data and voice) on the WRP400? Then how can I upload it once I modified it? I downloaded the SPC Tool and I read the Provisioning Guide, but I couldn't understand how to save it.
Thank you in advance
zbenko
Dear Luca,
You can download the XML configuration file from the device using this URL:
http://aaa.bbb.ccc.ddd/admin/config.xml
where aaa.bbb.ccc.ddd is your device's management IP address on the LAN side.
Please do not hesitate to post if you have any further questions.
Best regards,
Zsolt Benko
I tried several times, also after a reset to factory default, but it alway answers "404 Page Not Found!" I also tried using the url http://192.168.15.1/admin/config.xml&xuser=admin&xpassword=admin like on the Cisco SRP, but the result is the same.
Am I missing anything?
