I need VPN gateway to gateway with NAT for muliple subnets, RV082
daniel.synnott
I have a pair of RV082 routers and I'd like to configure gateway to gateway VPN tunnel as described in a cookbook, "How to configure a VPN tunnel that routes all traffic to the Remote Gateway," (file name Small_business_router_tunnel_Branch_to_Main.doc).  I followed this cookbook and found that my while the Main office has internet connectivity, the branch subnet doesn't have internet connectivity.
Routing does behave as advertised, where all traffic does go to the main office.  However, the 192.168.1.0 subnet in the branch office does not get internet connectivity.  I've read in other posts that the Main office router will only provide NAT for the local subnet, not the branch office subnet.  Is  there a way to configure the RV082 router to provide NAT for all subnets?
If not, which Cisco product will provide the VPN Tunnel connectivity as well as the NAT for all subnets?  Can the RV082 be used as part of the final solution or are my RV082s a  wasted expenditure?
Following is the configuration that I'd implemented, (real IP and IKE keys are bogus).
Gateway To Gateway
                    Remote                                                   Main Office
Add a New Tunnel
Tunnel No.                  1                                               2
Tunnel Name :               n1-2122012_n2-1282012        n1-2122012_n2-1282012
Interface :                  WAN1                                    WAN1
Enable :                   yes                                             yes
Local Group Setup
Local Security Gateway Type :        IP Only                IP Only
IP Address :                                 10.10.10.123             10.10.10.50
Local Security Group Type :          Subnet                subnet
IP Address :                                 192.168.1.0             0.0.0.0
Subnet Mask :                            255.255.255.0             0.0.0.0
Remote Group Setup
Remote Security Gateway Type :        IP Only                IP Only
IP Address :                                      65.182.226.50            67.22.242.123
Remote Security Group Type :             Subnet                 Subnet
IP Address :                                       0.0.0.0                192.168.1.0
Subnet Mask :                                     0.0.0.0              255.255.255.0
IPSec Setup
Keying Mode :                  IKE with Preshared key              IKE with Preshared key
Phase 1 DH Group :             Group 5 - 1536 bit                   Group 5 - 1536 bit
Phase 1 Encryption :              DES                                     DES
Phase 1 Authentication :          MD5                                     MD5
Phase 1 SA Life Time :          2800 seconds                            2800 seconds
Perfect Forward Secrecy :           yes                                    yes
Phase 2 DH Group :              Group 5 - 1536 bit                   Group 5 - 1536 bit
Phase 2 Encryption :              DES                                         DES
Phase 2 Authentication :          MD5                                    MD5
Phase 2 SA Life Time :             3600 seconds                       3600 seconds
Preshared Key :                        MyKey                                 MYKey
Minimum Preshared Key Complexity :     yes Enable              yes Enable
Te-Kai Liu
Level 7
Level 7
If you are running firmware 4.x on your RV082, you need to add an additional Allow access rule so the branch office subnet (seen as one of the multiple subnets of the main office) can get access to the internet. The firmware release note has more details about this.
http://www.cisco.com/en/US/docs/routers/csbr/rv0xx/release/rv0xx_rn_v4-1-1-01.pdf
Te-Kai Liu
Level 7
Level 7
Thank you, I passed over that part of the release notes.  This fixed the issue.
I do find that the connection is very slow, however.  Is this normal? or can this be addressed?
