IP Phone 3905
yossi.brandil
how can we connect the ip phone with a non cisco network
we are not able to change the settings.
Yossi
5 Replies 5
Leo Laohoo
Prepare the following:
1.  A TFTP server;
2.  DHCP Option 150;
3.  Firmware for the phone; and
4.  SEPmacaddress.cnf.xml file
Can you elaborate for me more, how to do it step by step
1.  A TFTP server;  -- what is it, i am using the https://www.voicenter.com/
2.  DHCP Option 150;  what do you mean ??
3.  Firmware for the phone; and  where can i get it
4.  SEPmacaddress.cnf.xml file - how can i builde it
When a Cisco phone boots up, it will get an IP address using DHCP.  Inside the DHCP IP address, there is an "option" called Option 150, and this enables the phone to know the IP address of the TFTP server.
A TFTP server is where one puts the SEPmacaddress.cnf.xml file and the firmware files in.
in the menu of the phone i can only choice "enable" or "disebale" in the DHCP
maby "alternate tftp"  is what you meen , i cane change it to "enabel"
i succes to config tftp and the phone is trying to register but it canot find "softkey.xml" file and some other files, where can i get all the files that i need ??
