08-28-2017 08:50 AM - edited 03-21-2019 10:54 AM
HI all,
I am using track and IP sla on my 3845 router. suddenly it stopped working. i cannot ping any internet IP address. even my ISP gateway. here is my IP sla and track.
track 10 ip sla 1 reachability
delay down 10 up 10
track 20 ip sla 2 reachability
delay down 10 up 10
ip sla 1
icmp-echo 50.x.x.x source-interface FastEthernet0/0/1
threshold 1000
timeout 3000
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 162.x.x.x source-interface FastEthernet0/1/0
threshold 2000
timeout 3000
frequency 3
ip sla schedule 2 life forever start-time now
route-map PBR permit 10
match ip address acl_natisp1
set ip next-hop verify-availability 50.x.x.x 1 track 10
route-map PBR permit 20
match ip address acl_natisp2
set ip next-hop verify-availability 162.x.x.x 2 track 20
route-map ISP2 permit 20
match ip address acl_internet
match interface FastEthernet0/1/0
route-map ISP1 permit 10
match interface FastEthernet0/0/1
Router#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 09:57:09 EST Mon Aug 28 2017
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 266
Operation time to live: Forever
IPSLA operation id: 2
Number of failures: 259
Router#show track
Track 10
IP SLA 1 reachability
Reachability is Down
15 changes, last change 1d21h
Delay up 10 secs, down 10 secs
Tracked by:
ROUTE-MAP 0
STATIC-IP-ROUTING 0
Track 20
IP SLA 2 reachability
237 changes, last change 1d21h
Tracked by:
ROUTE-MAP 0
currently 2nd ISP is working. even with these output my 2nd ISP is down,
all my users are on 2nd ISP. 1st ISP is not working.
If i directly connect PC to 1st ISP. its working.
Thanks.
Solved! Go to Solution.
10-13-2017 10:49 AM
08-28-2017 02:53 PM
Can you share the full config please?
You posted some PBR but we don't know where those PBR are applied.
Also if you take 1 of your IP sla, can you test from the router a ping to 162.x.x.x from interface FastEthernet0/1/0.
Remove any PBR first to make sure we capture the right output for the test.
PS: Please don't forget to rate and select as validated answer if this answered your question
08-29-2017 07:35 AM
here is my complete config
i cannot ping to 162.x.x.62 from interface FastEthernet0/1/0. even i cannot ping any public ip from my router including my 1st and 2nd ISP's gateway ip address.
08-29-2017 08:47 AM
If you can't ping your next hop from your interface that explain why your IP SLA are down.
Can you share the show ip int brie ?
Are they directly connected or physical cabling is passing through a switch ?
08-29-2017 10:35 AM
my both router interfaces are directly connected to ISP's devices.
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/1 unassigned YES NVRAM up up
FastEthernet0/0/0 unassigned YES NVRAM administratively down down
FastEthernet0/0/1 50. x.x.10 YES NVRAM up up
FastEthernet0/1/0 162.x.x.34 YES NVRAM up up
currently my 2nd ISP is working. but show ip sla stat shows its down.
08-29-2017 04:03 PM
08-30-2017 07:04 AM
ping 162.x.x.62 source fastEthernet 0/1/0
Sending 5, 100-byte ICMP Echos to 162.x.x.62, timeout is 2 seconds:
Packet sent with a source address of 162.x.x.34
Success rate is 0 percent (0/5)
i did
no ip sla schedule 2 life forever start-time now
sh track
Track 10
5 changes, last change 20:33:25
Tracked by:
ROUTE-MAP 0
STATIC-IP-ROUTING 0
Track 20
3 changes, last change 3d21h
Tracked by:
ROUTE-MAP 0
ITC-R1-R3845#sh ip sla statistics
Latest operation start time: 13:59:58 EST Tue Aug 29 2017
Number of failures: 24679
Latest operation start time: 10:33:43 EST Wed Aug 30 2017
Number of failures: 29
there is no output when i do debug track and debug ip sla
08-30-2017 05:08 PM
08-30-2017 05:37 PM
Are you directly attached to your ISP router?
Yes,
You need to figure out first why your ISP router isn't pinging.
I can ping ISP gateway if i connect my laptop direct to ISP device.
If you connect a laptop directly to your ISP router (as you did if I understood) to test, can you ping the ISP interface IP 162.x.x.62 ?
yes i can ping ISP gateway.
i was seach about this problem and came to know following bug "Timeout issue on IP SLA". is it ture?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCso46681/?referring_site=bugquickviewredir
08-30-2017 05:51 PM
Maybe you're facing that bug but before we need to be sure that your router ping its gateway and then we will be able to see what's going on with IP SLA.
Was it working before? What did you change? Can you test by changing the speed and duplex just in case!
Right now you've a weird issue not really related to IP SLA. On your point to point you can't ping the remote router.
Ok stop your IP SLA.
Shut your ISP1. Shut/no shut your ISP2.
Test it again.
If not pinging yet, :
a. can you paste the output of show interface FastEthernet0/1/0
b. change the cable just to be sure or test it
c. reboot your router
Let me know when you did that if you can ping the router.
08-30-2017 06:20 PM
yes everything was working perfectly. i did not change anything. suddenly it stopped working, i restart the router and 2nd ISP satarted working. while IP SLA shows timeout.
I dont think so it is cable issue. because 2nd ISP is working.
Test it again.
i shut down ISP 1 interface and sh/no sh ISP 2, still cannot ping ISPs gateway. but ISP 2 internet is working.
sh interfaces fastEthernet 0/1/0
FastEthernet0/1/0 is up, line protocol is up
Hardware is FastEthernet, address is fc99.4792.693e (bia fc99.4792.693e)
Internet address is 162.x.x.34/27
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 31/255, rxload 50/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 1/75/0/5 (size/max/drops/flushes); Total output drops: 2549
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 19904000 bits/sec, 2271 packets/sec
5 minute output rate 12296000 bits/sec, 2203 packets/sec
312616934 packets input, 2949511771 bytes
Received 4524 broadcasts (0 IP multicasts)
0 watchdog
376449590 packets output, 2019245671 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
I think cable is good
i reboot the router when this issue occurred.
08-30-2017 08:43 PM
08-30-2017 09:18 PM
my ISP 2 working through my "router" (where IP SLA is not working).
i am surprised IP SLA is timeout to both ISPs. i cannot ping both ISPs gateways. but ISP 2 is still working on my "router". i sh/no sh both interfaces. disable / enable IP SLAs as you suggested. but both IP SLAs are still timeout.
10-04-2017 10:50 AM
any thought on my question.
10-04-2017 10:59 AM
