IPSEC VPNs on RV215W router using certificates?
mark000018
Does the RV215W Wireless-N router support certifcates for site to site VPNs?
It seems that you have to use a Pre-Shared key.
Is this true as the remote endpoint will only accept certifcates.
Prithvi Manduva
Hello Mark,
Yes it supports certificates and yes it uses a pre-shared key.
Prithvi
Please mark answered and rate for helpful posts.
Thanks, Prithvi Please mark answered and rate for helpful posts.
Hi Prithvi.
I can't find anything in the documentation that shows how it can be done.
Want to use certificates for the VPN site-to-site authentiction and not pre-shared keys.
Is there an option somewhere that I'm overlooking?
IKE SA Parameters
Encryption Algorithm:
Authentication Algorithm:
Pre-Shared Key:
Did you get an answer?
Have the same issue
