Larry
lw00dd00wl
WRVS4400N Where is the Server Certificate located to get the VPN Client to work?
mpyhala
Level 7
Level 7
Hi Larry,
Thank you for posting. To get the security certificate, browse to VPN-> VPN Client Accounts. Look for Certificate Management and press Export for Client. Save the file in C:\Program Files\Cisco Small Business\QuickVPN Client (or equivalent) on the client PC.
Note that the certificate is not required to connect. It is simply a warning to the end user that they may not be connecting to the correct router. If the certificate is installed the warning popup will be disabled.
Thanks appreciate the info.
lwood
