Letter of Volatility / Sanitization procedure requested Router RV320 series
I need a letter of volatility for the Cisco Router RV320-K9-NA.  It must be an official document from Cisco that lists the memory details: size, type (EEPROM, RAM), volatile or non-volatile, user accessible or not, and how to clear it.
I am using this product in a secure area and require this information.
does anyone know where I can obtain this information?
Edgar
Philip D'Ath
I don't think you are going to get something like that for an RV320.
You'll need to at least step up to the Cisco enterprise range.  You can also buy FIPS kits of many of the routers as well.
You can also get things like secure eTokens for storing configs on.  This makes emergency destruction planning more straight forward.  Pull the secure token and the router looses its config (or you can use it to provision the routers config).
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/universal-serial-bus-usb-cards/product_data_sheet0900aecd80232473.html
