MEMORY UPGRADE to EXISTING 2951
csco10128790
Is it Possible to Swap out the Existing Memory 512MB and Replace it with 2GB Memory?
2951 INTEGRATED SERVICES ROUTER FTX1828AJR4
Does the router need to be reconfigured if so?
Richard Burts
If you look in table 8 in the document in this link it does indicate that the 2951 512 memory can be replaced by a 2 gig memory. If you do the upgrade I believe that the router will automatically recognize the new memory and you do not need to configure anything for it.
http://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/ordering_guide_c07_557736.html
Rick
Rick
