Minimum DRAM requirement not met
LolloD
dear all,
I have an issue with this router of our customer.
from tech-support file analyzed with CLI ANALYZER i receveid a message error:
"Minimum DRAM requirement not met
The minimum DRAM required memory in this platform is 256 MB and the platform has 128 MB. Running a platform with less than the minimum DRAM required could lead to unexpected results: Minimum Memory Requirements
Cisco 1801 (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory."
Can anyone help me to understand what it means?and if i need to replace this device?
Thank you
chrihussey
I'll assume you are running a 15.x IOS, which requires 256 DRAM. The older 12.x IOS only requires 128 DRAM. The router was probably originally purchased with the 12.x code and then was upgraded, that is why you're getting this result. There are two possible choices:
1- Not sure what particular model of 1801 you have, but you could purchase the additional memory. (MEM180X-256D=).
https://www.cisco.com/c/en/us/td/docs/routers/access/1800/1801/hardware/installation/guide/hig/10_hw.html#wp1043790
2- Resort back to the 12.x version of IOS.
https://www.cisco.com/c/en/us/products/collateral/routers/1800-series-integrated-services-routers-isr/product_bulletin_c25_515323.html
Hope this helps
chrihussey
Hope this helps
Resort back to the 12.x version of IOS and now the issue is solved.
Thank you so much.
