Monthly WAN Data Usage on RV345
parkernathan
Is there a way to check to see how much data usage I use per month over the WAN (WAN1) on the RV345? I'm on an unlimited WAN connection with my ISP, so it doesn't matter for data caps, I'm just curious if I am able to locate this information if I ever did need it.
Thanks!
Nathan Parker
pieterh
the RV may show current data usage, but not historically over a month.
you'll need some external software for that to query the RV using SNMP and aggregate the data.
there are many monitoring tools that can do this.
pieterh
Great to know. Thanks!
Nathan Parker
