le 02-18-2015 10:16 AM
I need a WIC card for OOB remote management for a cisco 2911 router. I am being told the WIC-1AM-V2 is what I want to use but looking at the below link the Cisco 2900 series is not listed as compatible. Does anyone know the part number for a integrated modem card for the 2911 or whether the WIC-1AM-V2 is compatible or not?
http://www.cisco.com/c/en/us/products/collateral/routers/2600-series-multiservice-platforms/product_data_sheet09186a00801d66bc.html?mdfid=268437949
Thank You for any insight.
le 02-19-2015 01:24 AM
Wrong forum. You should not wish for valuable answer here. Delete the thread here and recreate it in a forum dedicated to either WIC or 2900 series class of devices.
le 03-02-2015 11:31 PM
I have moved the discussion to the appropriate community.
Lavanya
CSC Moderator
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
