Please help with setting up wifi for Cisco Router RV 180W. LOGIN CREDENTIALS DO NOT WORK
larryc.nu419
Hi please help me in setting up my wifi. I have a Cisco Router RV 180W and the login credentials don't work to get into the configuration page.
Here is what it says in the directions. The username is cisco and the password is cisco
2014-01-01 16_15_33-www.cisco.com_en_US_docs_routers_csbr_rv180w_quick_start_guide_rv180w_qsg.jpg
But when I type that into the page, here's what I get:
Please help me.
I've tried the following combinations for usernames/passwords and they all DON'T work:
cisco/cisco
admin/admin
admin/cisco
cisco/admin
Please help me get through this step.
mpyhala
Level 7
Level 7
Larry,
When you did the initial configuration, the router should have forced you to change the PW. Try to remember what you changed it to. The username should still be cisco.
If you cannot remember the password, follow the instructions in the Quick Start Guide to reset the router to factory defaults and reconfigure it.
- Marty
