Port Forwarding Service Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-28-2016 01:13 PM
I have a RV042G Firmware Version: v4.2.2.08 that will not accept entries in the Setup - Forwarding - Service Management.
Currently there are 49 entries, some for Exchange, some for web server, some for remote desktop.
I need to make more entries and the last couple times the entries are not saving.
I am under Setup - Forwarding and then click Service Management to add to new service name and port assignment. I enter the name select the protocol and the port and click Add to List, the cursor goes back to the service name block. I can try to re-enter the service and it tells me it is already in the list so click OK, Cancel or Close (I've click all 3). Ok or Close takes you back to the forwarding menu where the new service should be on the drop down list but it isn't. I thought maybe there was a maximum # of entries but I started having the problem when there were only 20 entries. Usually if I just keep putting the entry in it will take eventually; however now I've been entering over an hour and it will not take it.
Can anyone provide assistance?
Darrel
- Labels:
Small Business Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-28-2016 02:08 PM
I see 4.2.3.07 is out for this device. Maybe try an upgrade?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-28-2016 02:13 PM
Can't do that during the middle of a workday - I'll try that tonight at midnight.
