10-06-2018 01:49 AM - edited 10-06-2018 04:15 AM
Hi all,
I've bought a Cisco SB RV345 for a client that wants to provide internet to some building management devices.
For this purpose we've setup a RV345 using two WAN connections.
WAN1: PPPoE connection over a 4 Mbps Fiber VLAN (connected to a Cisco ASR920 provided by Tele2)
WAN2: Static routed back-up connection over 30/3 Mbps VDSL (connected to a Cisco 887VA router)
My WAN2 connection (that is supposed to be used as back-up connection) does work.
My problem is the PPPoE connection does not seem to work (it doesn't get connected and IPv4 is shown as 'down').
What I've tested:
- Setup the PPPoE on WAN2 interface (did not resolve the issue)
- Tested on Firmware 1.0.01.18 and 1.0.01.17 (no success)
- Connected my Win10 laptop to the ASR920 and setup PPPoE on my laptop (this did work)
The logs of the RV345 don't tell me much either:
2018-10-05T16:31:05+02:00 notice network netifd: Interface 'wan1p' has link connectivity
2018-10-05T16:31:05+02:00 notice network netifd: Interface 'wan1' has link connectivity
2018-10-05T16:31:05+02:00 notice network netifd: Interface 'wan1p' has link connectivity loss
2018-10-05T16:31:05+02:00 notice network netifd: Interface 'wan1' has link connectivity loss
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.473652] eth2: pfe_gemac_init
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.473634] hif_lib_set_rx_cpu_affinity:Client (1) and HIF Rx processing will use same cpu
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.473621] pfe_hif_client_register
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.473608] hif_process_client_req: register client_id 1
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.473116] eth2: pfe_eth_open
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.460832] pfe_hif_client_unregister
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.460818] hif_process_client_req: unregister client_id 1
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.460799] hif_lib_client_unregister : client: e6a003a4, client_id: 1, txQ_depth: 2048, rxQ_depth: 2048
2018-10-05T16:31:05+02:00 info kern kernel: [ 671.426499] eth2: pfe_eth_shutdown
2018-10-05T16:31:04+02:00 notice network netifd: Interface 'wan1p' has link connectivity
Any help or suggestions would be appreciated.
Kind regards,
Peter
10-11-2018 05:52 AM
Hello
Try to setup PPPoE for both IPv4 and IPv6. It seems to help in my case.
10-15-2018 07:47 AM
I've tried to setup PPPoE on IPv6 as well, but no success.
Based on Cisco TAC Feedback I've also tried to set MTU to 1492 or 1472; both without success.
I did notice that the port on the CPE is configured as 100 Mbps Full Duplex; but when I set the RV345 to these settings, I don't get a link (I do when I set the port to 100 Mbps Half Duplex, or Auto Negotiate).
Kind regards,
Peter
