PPTP Server on RV260W does not work
I recently acquired a Cisco RV260W VPN router and was trying to set it up as a PPTP server, to be able to login to the office from the road.  I setup the options but cannot get it to work.  On Windows, I get an error in the log:
The error code returned on failure is 691.
On the RV260W log, I get the following error:
pptp: rc_read_config: can't open /etc/radiusclient/radiusclient.conf: No such file or directory
pptp: RADIUS: Can't read config file /etc/radiusclient/radiusclient.conf
pptp: Peer [Name of User] failed CHAP authentication
pptp: Connection terminated.
Has anyone been able to make this work?
cefalany
I have a similar problem. PPTP on Windows 10 previously connected to our RV320's. The same configuration does not connect to our new RV260s. Have you had any success?
