04-05-2020 06:32 PM
After upgrade, I just can't figure out how to resetup my PPTP VPN routes. Just doesn't work.
04-06-2020 12:44 AM
Hi Joe,
My name is Puneet sandel and I am from Cisco small business technical support center. Once the router has been upgraded to the latest firmware, make sure the PPTP tunnel still exists under VPN.
If not we will have to setup the PPTP tunnel again on the router and then on client.
Please find the link to configure PPTP on RV320. Although the firmware in the below doc is old but the process remains the same.
I hope this will resolve the issue and please do not forget to save the configuration from running to start up configuration after making the changes.
Please mark the thread as solution if it helps.
Puneet Sandel
Technical Consulting Engineer-Level 2
Global CX Centers – Small Business Support
04-17-2020 05:32 PM
