Problem changing VLAN IP address
Jazzyman11
I have a working VLAN setup as shown below but when I try to change VLAN ID#3 IP address to 10.90.206.33 I get an error
"Configured IP Address already in use". Any ideas?????
Tom Watts
Hi Steve, considering you're using a /28 subnet mask I'd think the router would not be so literal... but apparently it is.
I'd recommend to set vlan 3 to some arbitrary subnet like 192.168.241.1 then change it to your desired 10.90.206.33
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
thanks for your suggestion. Vlan 3 changed to 192.168.241.1 ok but failed to chage to 10.90.206.33. Same error
"Configured IP Address already in use". So close yet so far!
Cheers
Steve
Hi Steve, can you delete the vlan 3 and try?
I'm not sure why it wouldn't take it unless you have some configuration (service) somewhere occupying that subnet (such as a port forwarding, dns, etc)
-Tom
