Problem in connecting SRP521w with CCA v3.2
sherly_nie
Hi guys,,
I have a problem in connecting SRP521w with CCA v3.2.
I tried to connect the device with CCA but it said that that the device is unsupported.
I already upgraded the router's firmware with v1.01.26.
Is there anyone know how to solve this problem?
Thanks in advance..
Here is what the CCA looks like everytime I try to connect with the router  :
sherly_nie
Hi guys,,
The CCA no longer shows unsupported error message. I can connect the router with CCA right now, but it shows "Unreachable : Unknown Status". I can't see the front panel of the device and I can't configure anything.
Is there anyone know how to fix it?
I am really confused right now.
Thanks in advance.
