Problem VPN RV082 and RV042 file transfer not
ethan1988
i have 2  router connected via vpn. 1 rv082 and 2 rv042
theyconnect fine.and i can ping various pc's and servers from various pcs back and forth without problem.
the problem i am having is i cant access any files or network resources across the vpn.
i have dns and wins pointing to other network, but when ping by name host is not found.
also trying to access by \\192.168.xxx.xxx times out.
what am i missing to get this to work.
also I can not connect using quick vpn client get the following error
failed to establish a connection
this colud be caused by one of the following:
1.. Incorrect password
2   No valid IP for the network card
3   Incorrect server adress
4   Windows vista /windows 7 with windows firewall, which disabled IPSec service
5   Local Ip address conflicts with the subnet of remote VPN server-
I checked and the configuration is ok, firewall and ipsec windows service disabled.
help please. I'm worried
william montenegro
ethan1988
help please
William,
This will need some in-depth trouble shooting and over looking of existing configuration on each side of your tunnel. I would recommend calling Cisco Small Business Support Team and open a support case (Support Numbers)
Jasbryan
